You can view and configure the DHCP parameters on a specific port or VLAN.
You must configure an IP interface on the interface.
Use the data in the following table to use the ip dhcp-relay command.
The no ip dhcp-relay command disables DHCP Relay, it does not delete the DHCP entry.
Variable |
Value |
broadcast |
Enables the device to send the server reply as a broadcast to the end station. After you disable this variable, the device sends the server reply as a unicast to the end station. |
circuitId |
Enables Option 82 circuit ID on the interface. |
clear-counters |
Clears DHCP Relay counters for the interface. |
fwd-path <A.B.C.D> [vrid <1-255>] |
Creates a forward path server with a virtual router ID (or VRRP ID), a mode, and a state. A.B.C.D is the IP address. vrid <1-255> is the ID of the virtual router and is an integer from 1 to 255. |
fwd-path <A.B.C.D> disable [vrid <1-255>] |
Disables a forward path server with a specific value and virtual router ID. A.B.C.D is the IP address. vrid <1-255> is the ID of the virtual router (or VRRP ID). |
fwd-path <A.B.C.D> enable [vrid <1-255>] |
Enables a forward path server with a specific value and virtual router ID (or VRRP ID). A.B.C.D is the IP address. vrid <1-255> is the ID of the virtual router (or VRRP ID). |
fwd-path <A.B.C.D> mode <bootp|bootp_dhcp|dhcp> [vrid <1-255>] |
Configures the forward path mode for a VLAN. This command string is available only in VLAN Interface Configuration mode. A.B.C.D is the IP address. vrid <1-255> is the ID of the virtual router (or VRRP ID). |
max-hop <1-16> |
Configures the maximum number of hops before a BootP/DHCP packet is discarded. The default is 4. |
min-sec <0-65535> |
Configures the minimum seconds count for DHCP. If the secs field in the BootP/DHCP packet header is greater than this value, the device relays or forwards the packet; otherwise, the packet is dropped. The default is 0 seconds. |
mode <bootp|bootp_dhcp|dhcp> |
Configures DHCP mode to forward BootP messages only, DHCP messages only, or both. The default is both. |
remoteId |
Enables Option82 remote ID on the interface. |
trusted |
Configures the DHCP circuit as trusted. |
include-secondary <parallel | sequential> |
Enables DHCP Smart Relay in one of the following modes:
By default, Smart Relay is disabled. Note:
This parameter is optional and applies only to a VLAN interface. |
